Old 13-Mar-2013, 12:46 AM   #2
darkmatter
A rotor connects between 2 antenna masts and is made to be able to turn the direction of the antenna. Most people will tell you not to get one because you will have to rescan your tv every time you change the antenna position. The prefered method is usually to have a whole second antenna and cable into your house on an a/b switch. I'm new to this and there are alot of more experiance people on this site.
darkmatter is offline   Reply With Quote
