Old 12-Mar-2013, 8:51 PM   #2
The VHF signals call for a Winegard HD5030, http://www.winegarddirect.com/viewit...0%29&p=HD-5030 pointed at about 300°.
To add PBS and an independent station (KSAS, Fox & Antenna TV network), point an Antennas Direct 91XG or DB8E at about 5°. You can merge the UHF and VHF antennas into a single coax with a UVSJ, http://www.antennasdirect.com/store/..._combiner.html A CPA-19 preamp would be helpful if you have 50' or more cable run or need to split to more than one TV.
http://www.antennasdirect.com/store/...V-Antenna.html
http://www.amazon.com/Antennas-Direc...eywords=CPA-19
http://www.3starinc.com/ is one of several vendors that has a wide variety of mounting hardware.
