Yes you can use the coax that is used to distribute the satellite signals.
You did not say one way or the other if you will be connecting the antenna to a active satellite system.
Some times this can be done and sometimes not.
Dependes on the satellite system hardware that is in place.
If you do not know or understand the connection hardware connections , then get a satellite system installer to evaluate the system hardware.
I recommend that if you are discontinuing satellite service , then discontinue the service and Remove the satellite system hardware , multi switches , di plexers , splitters , and etc..
And then use the coaxes that are in place to distribute the Digital Broadcast Tv Reception to the locations of the Tv receivers.
___________________________________________
If you provide your tvfool radar plot report , this will be a big help to evaluate your reception situation and recommend antenna and amplifier and etc. .
If the Broadcast Tv Antenna will be more then 25 feet above ground then use the higher antenna height.
If not then use a 25 feet antenna height to make a tvfool radar plot report with the exact address.
