Old 9-Mar-2013, 7:58 AM   #4
Higher antenna height and less to no signal blockage is the Key to your reception situation/location.
25 Feet is stronger Tv reception signal strengths.
Going higher then 25 feet will make reception more stronger.
Here are some antenna mounts for a higher antenna height with no guy wires.
http://www.ronard.com/Tripods%200703/4712.html.
http://www.palcoelectronics.com/pe300.aspx.
_____________________________
Aim the YA1713 VHF high band antenna at about 250 degree magnetic compass direction.
---->Use only one 91XG and aim it at about 240 degree magnetic compass direction.<----
Combine the YA1713 and the one 91XG with the UVSJ and connect the AP8275.
_________________________________
As always , trees and tree leaves do a good job of , multipath/reflecting , absorbing , blocking , Digital Broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
Digital Broadcast Tv tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
Do a Double Rescan , http://www.dtv.gov/rescan.html
