Old 9-Mar-2013, 4:08 AM   #4
The C5 receives both VHF and UHF.
As stated it is 'shot' at receiving both directions with 1 antenna.
The Digital Broadcast Tv stations/channels in the Green and Yellow reception zones of the tvfool Digital Pending Applications Included should be received.
If both directions are not received then , a second antenna can be installed , the C5 will be aimed aimed at 345 degree magnetic compass direction and a second C5 will be aimed at about 250 degree magnetic compass direction.
The 2 antennas will be 2 separate antenna systems that Will Not be connected on to one coax.
A 1 antenna system installation is easier to deal with. Then 2 antenna system installation.
