Old 21-Oct-2010, 2:12 PM   #3
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
Most people in the Montreal area are used to seeing the Burlington= Pittsburgh TV stations, and I suspect that you are having some difficulty with your US stations. WVNY and WFFF, ABC and FOX respectively, are the hardest stations to get in the Montreal area, and WVNY is on VHF channel 13, and is usually not well-received on a UHF only antenna. You may want to reconsider your attic installation, even thought the weather in your area can be harsh, and add a VHF yagi like a Winegard YA-1713 aimed at Mt. Mansfield. The Mt. Royal stations in Montreal should be no problem, but, remember that they will go all-digital by August 31, 2011, and you may then need a rotator to see the Mt. Royal stations AND the Mt. Mansfield stations.
