Old 8-Mar-2013, 9:01 PM   #1
PKinPA
Help with antenna set up
Here is my Tv fool report:
http://www.tvfool.com/?option=com_wr...1ddafb32ec73ee
about years ago (before directv had locals) I installed an antenna system in my attic. (I'm aware of the signal loss, wish I was aware of this site) My setup includes 1 yagi style uhf only pointed @ 340 degress, 1 yagi style uhf only pointed at 154 degress. they each have their own pre amplifier with the cables ran through interior walls to basement. after the power adapters i combine both with a 2 way combiner/splitter to a CM-3414. All tvs in the house receive real channels listed in tv fool report (top to bottom) 9 through 41. even real ch 6 (vhf lo).
I also have a spare uhf/vhf/fm antenna not used but in attic.
My goal is to receive real channel 45 (wolf-tv)
Question for the experts - if I point my uhf/vhf/fm and uhf yagi @ 340 degress (and adjust until wolf is received) connected to a UVSJ and only use one down lead with amp to cm-3414 do you think I can receive channels from 154 degress from the back of the antennas listed.
also if I leave the antenna as is, can I join the two together in the attic before adding the pre amp that way I could eliminate of of the basement feeds.
Thanks for you input. and I don't have the model numers of the antennas or pre amps. they were all purchased at radio shack 12 years ago.
PKinPA is offline   Reply With Quote
