Old 8-Mar-2013, 7:26 AM   #2
For a 1 antenna shot at receiving both the Washington DC and Baltimore Digital Broadcast Tv stations/channels in the Green and Yellow reception zones with 1 antenna.
Above the roof mounted to the chimney , install a Antennas Direct , Clear Stream 5 , aimed at a in between aim direction of about 295 degree magnetic compass direction.
As always , the starting antenna aim direction is the -->starting antenna aim direction.
The antenna aim can be adjusted for best reception.
((Another antenna aim direction to try is about 215 degree magnetic compass direction.))
_____________________
Ronard makes a High Quality chimney antenna mounts , http://www.ronard.com/ychim.html , buy at ,http://www.solidsignal.com , by typing the word ronard in the solidsignal search box or buy from ronard.
____________
Install a Channel Master CM3410 distribution amplifier.
_________
Use a 6 way splitter. Leviton 47690-6.
Put a 75 ohm terminator on the unused output of the 6 way splitter.
((Every time a split takes place the signal is reduced.))
If it is not actually 5 Tv's connected , and it is really 4 Tv's connected the use a 4 way splitter.
If it is not actually 4 Tv's connected , and is really 3 Tv's connected then use a 3 way splitter.
If it is not actually 3 Tv's connected , and is really 2 Tv's connected then use a 2 way splitter.
If it is not actually 2 Tv's connected , and is really 1 Tv connected then use No splitter.
_______________________
Here are some places to buy antennas and etc.
http://www.solidsignal.com.
http://www.amazon.com.
