Old 7-Mar-2013, 6:41 PM   #7
elmo
I have a feeling that the antenna you have may not tune those VHF stations very well, like WABC, WPXO, WNJB, WKOB. Check em out and see. And the amp on the antenna is likely gonna be trouble for all frequencies, as you are getting some very strong, close signals in most cases. If there's a switch to turn it off, try that first. If not, the antenna Teleview has recommended will do it fine, as long as it has a clear view. WNJB would come in off the back of the antenna, so it's reception might not be optimal, but should be pretty good from what I can tell. You may need an FM block with that much VHF available to you, as I assume that there is plenty of FM radio around you too. You can run an FM report if that's an issue.
