Old 6-Mar-2013, 4:21 PM   #4
I did my best to get Digital Tv stations UHF and VHF with 1 HD7698P antenna recommendation.
________________________________________________________________________________
For the UHF Digital Tv stations/channels As a Test , Yes install the DB4e antenna with the CM7777 preamp , at 55 feet antenna height , aimed at about 190 degree magnetic compass direction.
The Digital Tv stations that will 'shake out' for reception 'in some way' are ,
CHCJ 35 .
CKVP 42 .
CKVR 10 .
CHCH 11 .
WPXJ 23 .
Do the test with the DB4e at 55 feet antenna height.
And a second antenna , a Antennas Direct C5 antenna for reception of either , CKVR 10 or CHCH 11. And perhaps both CKVR and CHCH can be received with C5 aimed somewhere in between.
The C5 comes with a UVSJ , to combine the DB4e and C5 together.
The CM7777 is connected to the output of the UVSJ so both antennas are amplified.
Here is a , Aluminum , Light Weight , Free Standing , No Guy Wires , Lay Over Tower.
Do all antenna installation and adjustments standing on the ground.
http://www.palcoelectronics.com/pe300.aspx.
