Thanks very much. I'm grateful for your help and the resource this site provides. I'll use compression type. Should my RG6 be all copper or copper over steel (Lowes)? No need for quad shield right? No reason to wait a month for leaf-out to test for interference /multi-path?
I hope to temp it in like this: put concrete block on roof, add pipe, pour remainder of block with concrete, remove pipe piece when concrete won't slump. I'll end up with a slanted hole that's plumb to receive about a foot of a temporary mast. I'll test with that, if it goes well at 28 feet, I'll order the Ronard 4712 to go with 10 foot mast, 3 feet of which is in the tripod.
