As I have stated , there is No signal strength advantage to mounting at 40 feet antenna height above the ground.
There is not that much signal strength change if the HD7698P antenna is installed at a lower antenna height.
However the HD7698P antenna -->Must be installed and mounted Strong and Sturdy.
If a weak and whimpy antenna mount is used then you will buy another antenna if the antenna falls over.
The antenna Is Not that heavy.
But even being Not That Heavy.
Duct tape and plastic straps will not hold the antenna up for very long.
Do not cut corners on installing mounting the antenna.
