Old 5-Mar-2013, 4:19 AM   #5
Install a Antennas Direct Clear Strem 2 Complete UHF/VHF antenna aimed at about 25 degree magnetic compass direction.
http://www.antennasdirect.comClearSt...VHF-Combo.html.
Remove the Reflector Screen from the CS2 Complete antenna.
The reflector screen is not the UHF reception loops.
The reflector screen is not the VHF reception rods.
The reflector screen is a screen , remove the reflector screen.
With the reflector screen removed the CS2 Complete antenna will receive at the front of the antenna and back of the antenna.
Your location has receivable Digital Broadcast Tv stations/channels in the directions of , north east , south east , south west.
_________________
Use All New coax cable for outside coax. <--Important.
Use the coax that has the compression type connectors on the ends of the New Coax. <--Important.
Do not use the Old type of connectors on the coax that are the crimp type connectors.<--Important.
Only use New Coax.<--Important.
Install the CPA-19 preamp.
Use All New coax.
Important<--> As a Test to prove reception the coax that goes from the preamp to inside the house Will Be 1 Loooong New coax.
Run the New Loooong coax through a open door or window direct to the location of the Tv.
And connect the New Loooong coax to the preamp power injector and the preamp power injector is connected to the preamp power supply , and the New coax to the Tv from the power injector is connected to the Tv.
NO Splitters. NO coax ground block connector. NO couplers.
Use ALL New Coax.
______
Digital Broadcast Tv Tuners can develop - Digital Glitches - that are not cleared out with a simple channel scan.
Do a Double Rescan.
http://www.dtv.gov/rescan.html..
______________
