Old 21-Oct-2010, 4:00 AM   #2
Your antenna looks like a good choice. It has some gain and is not as critical about aiming as larger antennas often are.
However, you should still try adjusting the aim in small steps to be sure you have the best signal available. In this case I expect the antenna to do best when it is facing just a bit south of due east.
Also, are there wires or metal ducts near the antenna, if so, try moving the antenna away from those metal objects.
Be sure to examine connections for looseness and check that the coax is not bent sharply or otherwise damaged.
