I feel some of your pain...
A Winegard HD-9032 or Antennas Direct 91XG plus an Antennas Direct PA-18 amplifier would be a possible option for channels 14 and higher.
If you want to try for channels ranging from 7 - 13, then the combination of a Winegard YA 1713 (for high band VHF) and one of the UHF antennas above into a Channel Master CM7777 amplifier.
I took the liberty of dropping those coordinates into the mapping tool to look at what could be gained by going up... at 60' AGL there should be significantly more signal. So, can you consider a pole or tower instead of a small nuclear reactor? LOL I think your best hope is in getting the antenna as high as possible.
Do you have a neighbor on higher ground that would be interested in a joint venture?
Reason: another idea that stopped me from falling asleep
