Old 4-Mar-2013, 6:14 PM   #9
Proceed in the following order, one at a time:
1. Eliminate the amplifier completely. Turning it off or unplugging its power doesn't count.
2. Relocate the antenna to the side of your home that offers a clear path towards Bithlo while simultaneously putting the bulk of your house between the antenna and the tower for WVEN which is located 5.2 miles to your west north-west. This will tend to help weaken WVEN's signal/
3. Add a variable attenuator and see if "dialing down" the incoming signal power will drop WVEN's signal power below that which might be causing the interference. You are not going to "eliminate" the WVEN signal in any event, we just want to weaken it without killing the signals from Bithlo.
