Old 4-Mar-2013, 5:07 PM   #4
Antenna rotators Are Not channel surfing friendly , must wait for antenna to rotate , and there will be Domestic Situations about the direction the antenna is aimed.
For reception of the Lima and Dayton areas Digital Tv stations.
Install 2 Separate antenna systems.
2 Separate antenna systems with Remote control A/B antenna switches is Channel Surfing Friendly.
____________________________________
Antenna system A.
For reception of the Lima area Digital Tv stations/channels , above the roof in such a manner that the reception is not blocked by the roof and house to the , north east , install a Winegard HD7694P antenna aimed at about 35 degree magnetic compass direction.
Try reception with no antenna system amplifier.
For 2 Tv's connected , use a HFS-2D , 2 way splitter.
Buy the HFS splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
_______________________________________________________________
Antenna system B.
Above the roof so that reception is not blocked by the roof and house in the direction of south.
Install a Channel Master CM4228HD antenna aimed at about 178 degree magnetic compass direction.
Try reception with out a antenna system amplifier.
For to Tv's connected use a , HFS-2D , 2 way splitter.
________________________________________________________________
Here are above the roof antenna mounts.
http://www.ronard.com/909911.html , use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html , use a #4560 eave antenna mount.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal buy typing the word ronard in the solidsignal search box or buy from ronard.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com , http://www.channelmasterstore.com.
_____________
Use Remote control A/B antenna switches , http://www.mcmelectronics.com , #32-4425.
At each Tv location.
