Old 4-Mar-2013, 11:43 AM   #6
Probably adjacent channel interference on some of the tuners from local Univision affiliate in your back yard.
Confirm whether or not you're using an amplifier anywhere in the circuit. You should not be using one.
Try some combination of antenna location (block Univision, favor Bithlo) and external attenuation and you should be able to solve it.
