Old 4-Mar-2013, 5:20 AM   #2
As always , Attics Are Not a reception friendly environment and Never Will Be a reception friendly environment.
To try for reception with a antenna in the Attic , of the Locals in the Green and Yellow reception zones of the tvfool Pending Applications Included Digital radar report and channel list install a Antennas Direct Clear Stream 2 Complete VHF/UHF antenna aimed at about 260 degree magnetic compass direction.
http://www.antennasdirect.com/store/...VHF-Combo.html.
________________________
Try reception with No preamplifier if the house/roof has asphalt composition type singles and no metal backed insulation and no metal siding on the roof end walls.
__________________________________________________
WBNG-TV VHF channel 7 CBS and CW -->Will Not Be Received<-- with any type or kind of antenna Big or Small antennas in the attic , WBNG-TV 7 , Will Not Be Received in the attic , it will not happen.
As always , trees and tree leaves do a good job of , multipath/reflecting , absorbing , blocking , Digital Broadcast Tv Reception and so do buildings and other obstructions including your own roof and house.
It is best to install the CS2 Complete antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com.
