Thread: Cpa19
Old 4-Mar-2013, 4:05 AM   #1
BobHaskett
Cpa19
May be a dumb question, but does it matter which way the CPA19 egg shape faces on the mast? Should the clamp be in the back with the egg facing the same direction as the antenna? Or should the clamp be facing the same direction as the antenna?
Is it OK if the Power Inserter is only 15 feet downstream from the antenna and the splitter is another 40 feet downstream from the power inserter?
BobHaskett is offline   Reply With Quote
