Old 4-Mar-2013, 12:56 AM   #28
darkmatter
I just had a thought and was wondering if this might be causing the issue with my signal problem. The hd7084p antenna is wired like this. There is a 6 foot cable from the antenna to the preamp and then there is a 35 foot cable from the preamp to the power block inside my house. From the preamp power block there is a 15 foot cable to a 2 way splitter . From the splitter 1 cable goes to the bed room tv a cheap 22 inch Dynex and the 2nd cable (a 6 foot section) goes into a tripplite a/v surge protector. Finally a 6 foot cable from the surge protector to the main tv (Samsung Plasma). If I remember correctly I get better reception in the bed room. Could my issue be because of the surge protector? I am going to try a couple things 1st install the distribution amp after the splitter to the main tv (Samsung) 2nd If that doesn't work I will try taking the splitter out and only run the antenna to the main TV. I'm wondering if the issue might be the sensativity of the main tv tuner.
darkmatter is offline   Reply With Quote
