Old 4-Mar-2013, 12:32 AM   #7
jd1879
I put up the Winegard antenna you suggested. The only station i don't get without breakup is the fox (13.1) station. I have not installed the amplifier since its not here yet. Would this and some antenna direction adjustment likely help this without having to buy a second antenna?
Antenna is about 25 feet up facing 185 degrees.
Thanks.
jd1879 is offline   Reply With Quote
