Old 3-Mar-2013, 8:29 PM   #5
BobHaskett
Originally Posted by clemmima View Post
I have an Insignia 42" 720p plasma, Samsung 32" LCD tv, and a Magnavox 15" LCD(not used much). They are attached to a Samsung DVD, Wii, and Roku respectively to get internet(Netflix, Hulu etc.)
Present set up is Comcast TV, Internet, home phone. Am looking to keep Comcast Internet(or perhaps switch to Century Link high speed internet-only two choices) drop home phone, and drop Comcast TV to go to ota TV with Netflix, Hulu etc. We have 2 desktop computers and 4 laptops with wifi set up. Am thinking about getting some kind of tuner to get TV to the computers also.
I'm thinking that I need to get something big as far as an antenna goes and that the ANT751R is not going to work. But since I've already purchased it, could it be used in conjunction with another antenna, should I try it just in case it might work, or will it be completely worthless in my situation and I just need to send it back and pull out the big guns right away?
Just fiddling around with height on the fool report-there doesn't seem to be a lot of difference in raising the antenna or lowering it so I'm assuming that antenna size will be the difference.
I think ABC and CBS will give you trouble using a ANT751r. I am no expert but I have 2Edge to deal with as well, and my FOX with the same signal strength as your CBS was spotty at best. It comes in pretty reliably with a Clearstream C2V, but only 47 signal strength.
I am about to purchase a Winegard 7694p to try.
BobHaskett is offline   Reply With Quote
