Old 3-Mar-2013, 3:41 PM   #2
Indoor Digital Tv reception Is Not a reception friendly environment and Never Will Be reception friendly environment.
The best building construction for indoor Digital Tv reception is wood with wood or vinyl siding.
The following is a - Non complete list - of building construction that will further , multipath/reflect - signals bouncing all around , absorb , block , Digital broadcast Tv reception.
Concrete , concrete blocks , bricks , rocks , metal siding , metal roof , solar panels , metal beams , stucko Wire , and more.
______________________
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com.
Instal a TERK HDTVi (not the HDTVa) in a south facing , window , patio window.
Aim the HDTVi at about 180 degree magnetic compass.
Here is how to aim indoor and outdoor antennas , http://www.kyes.com/antenna/pointing/pointing.html.
If required use a loooong coax to connect the HDTVi antenna to the Tv.
The Tv Must Channel Scan for the OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv Setup Menu and select , 'Air Channels' / 'Antenna Channels'.
As always , trees and tree leaves do a good job of , multipath/reflecting , absorbing , blocking , Digital broadcast Tv reception and so do buildings and other obstructions including your own building.
It is best to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own building.
