This will be my last question on this matter. Is there a multi direction tv antenna that will work in my situation that would replace the winegard hd7084p. So i could get most or all the stations at 162 degrees and at least channel 69 from 32 degrees. The reason I ask is I have one of those tvs that needs to be rescaned everytime. I can't manually add stations. I want to try to get as many stations I can get with only 1 antenna. I now can get around 40.
