Research shows that WPXA-DT REAL UHF Digital Channel 51 , virtual number (14.1-2-3) ION and Qubo and ION Life.
Is at 295 degree magnetic compass direction.
So to squeeze in reception of ION , then aim the antenna more in the direction of WPXA , aim the antenna at about 260 degree magnetic compass direction.
-->-->-->-->More important then aim direction at this point , is get the antenna Up in the Air Above the Ground and above the roof so Digital Tv Reception Can Happen.<--<--<--<--
As always trees and tree leaves do a good job of , multipath/reflecting , absorbing , blocking , Digital Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
