Old 20-Oct-2010, 8:20 PM   #4
Originally Posted by John Candle View Post
http://forum.tvfool.com/showthread.php?t=860
"Also think about this , some houses have metal roofs , are the metal roofs grounded with ground wires. Also think about this , some houses have metal siding , is the metal siding grounded with a ground wires?"
When I observe installation such as metal roofs and siding I see important distinctions.
Unlike a metal roof system, the antenna system enters the occupied space, therefore reasonable steps should be taken to reduce (eliminate is impossible) the possibility that a fault condition could cause hazardous voltage to be present in the occupied space or that fault current could pose a fire threat.
In the case of metal siding, I know that codes address mobile-home grounding in-part because it is not desirable to permit the siding or frame of the trailer to become energized in a fault situation.
My hope is that more people will support OTA television and enjoy it safely.
