Old 2-Mar-2013, 12:55 PM   #6
Dagwood
Dagwood's Avatar
Originally Posted by teleview View Post
Please make and post a tvfool radar plot report with the antenna height above ground at 25 feet.
Or if the antenna is higher then 25 feet above ground then use that antenna height when making the tvfool radar plot report.
Use your Exact address to make the tvfool radar plot report.
I did that before I posted, but considering that things worked great for a year and a half after the installation I didn't include it in my original post. All things considered, would it matter?
What is the make and model number of the antenna??
What is the make and model number of the booster??
Pretty sure they are both Wineguards, but I'll have to get back on the roof to check and there's too much snow on it now, and according to the forecast, it will be a week or so before it melts off.
One more bit of info that may or may not be important: On a typical station, the signal strength bar will be way over on the right, not pegged out, but close. Then, maybe a few times an hour it will streak to the left, go back and forth, then the signal degrades. This usually lasts only for a few minutes then it goes back to full power for 10-15 minutes.
Dagwood is offline   Reply With Quote
