Old 20-Oct-2010, 7:45 PM   #3
Originally Posted by John Candle View Post
http://forum.tvfool.com/showthread.php?t=860
"The EASY WAY to find out about grounding in your lo-cal is to look at some Dish Network and Direct Tv installations."
"As part of a understanding and evaluation process , get some binoculars , drive around housing areas where houses are at , stop and look at Tv antennas on houses. Do any have a - separate - wire attached to the antenna that could be connected to a ground. . Think about what you have found out."
I agree. Much of what I have learned has been by observing and then pondering over what I have seen. Sometimes I learn how to do 'it' right, sometimes I learn how not to do 'it'. So I try not to jump to conclusions, giving weight to the credibility and authority of each source.
