Old 2-Mar-2013, 5:38 AM   #2
The Digital Tv stations are 85+ miles away , with 2 edge and tropo path obstructions , The Only Way to find out if Reliable Reception will happen is install antennas and try it.
Put Antennas Direct , New DB8e Ultra long range UHF Antenna to the test.
Install a DB8e , both panels , aimed at about 226 degree magnetic compass direction.
Install a Winegard YA1713 VHF high band antenna aimed at about 226 degree magnetic compass direction.
Connect the 2 antennas with a UVSJ = UHF/VHF - Separator/Joiner.
Type the letters uvsj in the , http://solidsignal.com , search box.
Connect the DB8e antenna to the UHF connection of the UVSJ.
Connect the YA1713 to the VHF connection of the UVSJ.
The YA1713 antenna on the bottom and DB8e antenna above separated by about 2 or 3 feet on the same mast.
Connect a Antennas Direct CPA-19 preamp to the remaining connection of the UVSJ.
Recommend do not use the CM3414 distribution amplifier.
To Prove reception , recommend connect to only 1 Tv at first.
No splitters.
As always , the starting aim direction of a antenna is the --> starting aim direction of a antenna.
Most Digital Tv's have a signal strength meter and some Digital Tv's also have a signal quality meter.
Here are places to buy antennas and etc. http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com.
Most likely the strong signal strength Digital Tv stations to the north and east will be received at , back and back angles to the , DB8e and YA1713 antennas.
