Old 1-Mar-2013, 5:54 PM   #11
Stereocraig
Originally Posted by seaverd View Post
GroundUrMast,
Thanks for the tips on using the hdhomerun to diagnose multipath. I definately have multipath...if I stay tuned to a station with the hdhomerun gui, I see signal quality bouncing from 100% down to 73% (lowest observed). That being said so far my recordings have not had any dropouts...Do you think I will be OK long term since I am still above 65%. Is there anyway to check/diagnose the jointenna to see what is wrong with it? I popped the case open and see the capacitors and tuned coils...I don't recall it ever getting dropped. At one point it was hooked to an antenna that had a preamp with a 5 volt power supply...could that have caused an issue?
Dan
I would certainly expect either a problem w/ the Jointenna, or the power injector, if the Jointenna isn't capacativly coupled.
