Old 1-Mar-2013, 3:46 PM   #7
Emu25
OK I have installed a test antenna at about 30ft. We used a Digiwave ANT-2280, VHF/UHF Yagi similar to the RCA ANT-751.
We started with 110 degrees mag azimuth then tried several different angles, even rotating the antenna 180 degrees to try to get 6(6.1) but to no avail.
Ended up with pointing the antenna 95 degrees, enough to receive the strong channels at 50 degrees, still getting the weaker channels at 118 degrees.
Overall we are getting 12 distinct TV signals.
Thanks all for your input.
Emu25 is offline   Reply With Quote
