Old 1-Mar-2013, 1:48 PM   #10
seaverd
GroundUrMast,
Thanks for the tips on using the hdhomerun to diagnose multipath. I definately have multipath...if I stay tuned to a station with the hdhomerun gui, I see signal quality bouncing from 100% down to 73% (lowest observed). That being said so far my recordings have not had any dropouts...Do you think I will be OK long term since I am still above 65%. Is there anyway to check/diagnose the jointenna to see what is wrong with it? I popped the case open and see the capacitors and tuned coils...I don't recall it ever getting dropped. At one point it was hooked to an antenna that had a preamp with a 5 volt power supply...could that have caused an issue?
Dan
seaverd is offline   Reply With Quote
