Thread: Antenna advice
Old 1-Mar-2013, 3:14 AM   #3
The tvfool radar report plot and channel list is showing that your reception location is one Very Few Places/Locations that has good reception of ,
Medium signal strength to weak signal strength and LOS = Line of Sight , of a Long List of - Many - Digital Tv stations at Very Long Distances of an amazing , 111+ and 112+ miles distance.
This is reception situation is truly unusual.
Please let there be no close 2 story houses to block reception in that direction.
Aim the HD7696P antenna at about 324 degree magnetic compass direction and Scan For Digital Broadcast Tv stations/channels.
The Tv/s Must Channel Scan for , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv Setup Menu and select , 'Air Channels' / 'Antenna Channels'.
