Old 28-Feb-2013, 1:46 AM   #3
A Simple 2 antenna reception situation.
This 2 antenna set up provides flexibility of reception.
Above the Peak of the roof in such a manner that the roof and house are not blocking reception to the west and east.
____________________________
Install a Antenna Craft Y5-7-13 VHF high band channels 7 thru 13 antenna aimed at about 280 degree magnetic compass direction.
With the Y5-7-13 antenna aimed west the Topeka VHF Tv stations/channels will be received.
There are no current VHF stations/channels at Kansas City direction.
And if some VHF high band Tv stations do begin transmitting in the future in the Kansas City direction. Then the Y5-7-13 antenna will most likely receiving them because the Y5-7-13 antenna receives good at the back of the antenna.
_____________________________
Also install a Antennas Direct , ClearStream 4 UHF antenna aimed at about 280 degree magnetic compass direction.
Remove the Reflector Screens from the CS4 antenna.
With the reflector screens removed from the CS4 antenna the CS4 will receive the Topeka and Kansas City UHF Digital Tv stations/channels.
On the same antenna mast the , Y5-7-13 antenna is below the CS4 antenna.
Separate the antennas buy about 2 feet or so.
Connect the Y5-7-13 antenna and CS4 antenna together with a UVSJ. UVSJ = UHF/VHF - Separator/Joiner.
Type the letters , uvsj , in the http://www.solidsignal.com , search box.
The Y5-7-13 antenna is connected to the VHF connection of the UVSJ.
The CS4 antenna is connected to the UHF connection of the UVSJ.
And the remaining connection of the UVSJ is.
For 1 Tv connected use No splitter. No amplifier.
For 2 Tv's connected use a simple common 2 way splitter. No amplifier.
For outside coax connections it is best to use the coax that has the - Compression type connectors , not the old style connectors that are crimped on to the coax.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html, use the #4560 eave antenna mount.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
______________________________
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com.
As always , trees and tree leaves do a good job of , multipath/reflecting , absorbing , blocking , OTA = Over The Air , Digital Broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the , Y5-7-13 antenna and CS4 antenna at a location that has little to no obstructions of any type or kind in the direcetions of reception including your own roof and house.
The Tv/s Must Channel Scan for the Digital Broadcast Tv stations/channels , often named the 'Air Channels' or '[Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select , 'Air Channels' / 'Antenna Channels'.
