Old 20-Oct-2010, 7:15 PM   #7
No static at all
No static at all's Avatar
If the trees are pretty close they are likely causing multipath interference(signal reflections) which can create the scenario that will make only one of the strong channels unreliable. Try lowering /raising in 6 inch increments to find a sweet spot.
Re-check all the channels once WRAL becomes reliable to make sure your other channels are still OK. You may have to compromise with the height to make all channels reliable.
