Thread: Setup Help
Old 25-Feb-2013, 11:30 PM   #40
BobHaskett
Originally Posted by No static at all View Post
This is typical of multipath (reflected signal) & the only way to fix it is to move the antenna to where it can see a better quality signal. The ANT 751 is more directional & may be able to better combat the multipath, even mounted in the same spot. There are more VHF elements, so you have a better chance of grabbing more of a quality signal.
So out of curiosity, could a move up/down and left/right (compass direction) reduce or increase multipath? I am just wondering if I should spend my time moving the antenna up/down side to side on the current mount before physically relocating the antenna or trying a new one.
BobHaskett is offline   Reply With Quote
