Thread: Setup Help
Old 25-Feb-2013, 11:01 PM   #39
No static at all
No static at all's Avatar
This is typical of multipath (reflected signal) & the only way to fix it is to move the antenna to where it can see a better quality signal. The ANT 751 is more directional & may be able to better combat the multipath, even mounted in the same spot. There are more VHF elements, so you have a better chance of grabbing more of a quality signal.
