Thread: Setup Help
Old 25-Feb-2013, 9:35 PM   #38
BobHaskett
Originally Posted by No static at all View Post
Can you rise or lower the antenna any? Can you try the ANT-751 on the mount? The VHF signal is not reaching the VHF element on the antenna.
I could lower it but not raise it. It is at the very top of the mount. I thought about the VHF but NBC is VHF as well and it is not quite as strong as PBS is it?
I also just noticed that I can tune directly to it. It is registering a signal (but no picture), but fluctuates rapidly. My other signals are steady (if they change they may go from 67 to 68 every few minutes). When I tuned directly to PBS it bounced from 3 to 15 and would take larger jumps. For example: 3, 11, 3, 15, 4, 7, 15....Etc.
BobHaskett is offline   Reply With Quote
