Old 25-Feb-2013, 9:17 PM   #18
greenguy
It's 'best practice' regardless of where the antenna is mounted. It should not cost much in time or cash in most cases.
A summary of the basic steps are listed in post #20 in this thread: http://forum.tvfool.com/showthread.php?t=901. And here's a well written article with graphics: http://ecmweb.com/code-basics/articl...sion-equipment
thank you for the informative links. I plan on reusing some coax that DirecTV installed at the house previously and that coax already has a ground wire attached/bonded to the coax. Will that ground wire be sufficient? How can I tell if it is #10?
greenguy is offline   Reply With Quote
