Old 25-Feb-2013, 5:28 PM   #6
When it is time to move the antenna.
The antenna Must Be UP High above the High Point of The Roof so that the roof and house are not blocking reception.
Some of the Tv stations are Weak Signal Strength and require a clear shot for the best reception.
Because you have the CS2V antenna now.
Install the CS2V above the roof with the HDP-269 preamp.
Aim the CS2V antenna at about 170 degree magnetic compass direction.
These are the Digital Tv stations/channels and sub channels you are reaching out for.
WFSB , REAL UHF Digital channel 33 , virtual number (x) , CBS.
WTIC-TV , REAL UHF Digital channel 31 , virtual number (61.1-2) , FOX and Antenna Tv.
WUVN-DT , REAL UHF Digital channel 46 , virtual number (18.1) , Univision.
WEDH-DT , REAL UHF Digital channel 45 , virtual number (x) , PBS.
WCCT-TV , REAL UHF Digital channel 20 , virtual number (x) , CW and This Tv.
WVIT-DT REAL UHF Digital channel 35 , virtual number (30.1-2) NBC and Cozi Tv.
WRDM-CD REAL UHF Digital channel 19 , virtual number (x) , Telemundo.
WTNH-DT REAL VHF Digital channel 10 , virtual number (8.1) , ABC.
WRTN-LP REAL UHF Digital channel 48 , virtual number (48.1-2-3-4) , RTV and Cozi Tv and Tuff Tv and Classic Movies.
WZME REAL UHF Digital channel 42 , virtual number (x) , Me-Tv and RTV.
WCTX-DT REAL UHF Digital channel 39 , virtual number (59.1) MyNetwork.
These tv stations should be received with one antenna , without rotating the antenna.
(((( It is -->Very Important <-- to install the CS2V antenna In The Clear for reception of the Tv stations to the , south east , south , south west. WTHN , WRTN , WZME , WCTX , are Weak signal strength at your location. ))))
---->Do not underestimate the Desire that Trees have to , reflect , absorb , block , Digital broadcast Tv reception.<----
__________________________________________
Tv antenna rotators Are Not channel surfing friendly , must wait for antenna to rotate and their Will Be Domestic Situations about the direction the antenna is aimed.
The other receivable Digital Tv stations are to the , north east.
The Tv stations are.
WWLP , NBC.
WGGB , ABC and Fox and MyNetwork.
WGYB , PBS.
The Tv stations to the , south east , south , south west , have All those Networks. NBC , ABC , Fox , MYNetwork , PBS.
