Old 25-Feb-2013, 4:20 PM   #5
elmo
Originally Posted by slonkoski View Post
I ended up getting a Clearstream 2CV, mounted under eave above lower roof line, I get one more channel than with the coathanger special, oh well. Pointing about 110 degrees for now. Maybe in spring I'll pick up the large Winegard and do a chimney mount with rotator, but I'm pretty happy with current channels.
Did you get WTNH at 110 degrees? I'd suspect not, as it's just past 180, so you're about 90 degrees from it. Reception from the side of the CS2 will be weak. You need at least another 45 degrees south to get a decent signal, from what I can tell.
