Thread: Kabc la
Old 25-Feb-2013, 4:40 AM   #4
Check All outside connections. If water has inter any of the connections , then you can be sure that the water has traveled up into the length of the inside of the coax and the coax is now trash.
Use the Compression type coax connectors outside not the crimp type.
The compression type connectors are a much better seal to prevent water damage.
____________________________
Broadcast Digital Tv tuners can develop - Digital Glitches - that are not cleared out with a simple channel scan.
Do a Double Rescan.
http://www.dtv.gov/rescan.html.
To receive , Many , many , many , many , many , Digital Broadcast Tv stations/channels.
For a above the roof top antenna install a Winegard HD7082P antenna aimed at about 0 degree magnetic compass direction.
http://www.ronard.com/909911.html. Use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Use the #4560 eave antenna mount.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
Install a Winegard HDP-269 preamp.
Buy the HFS splitters at , http://www.solidsignal.com , http://www.hollandelectronics.com.
As always , trees and tree leaves do a good job of , multipath/reflecting , absorbing , blocking , Digital Broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7082P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The directions of reception at your location are , north west , north , north east.
______
The Tv's Must Channel Scan for the , OTA= Over The Air , Digital Broadcast Tv stations/channels , often named the , 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv Setup Menu and select , 'Air Channels' / 'Antenna Channels'.
