Thread: Setup Help
Old 24-Feb-2013, 8:47 PM   #32
BobHaskett
Originally Posted by No static at all View Post
I like option 2 better, but would opt for an 8 way amplified splitter instead of a pre-amp. Daisy chaining passive splitters after a preamp results in way too much signal loss downstream.
Why don't you just try this scenario with the ANT751 first since you already have it? If you find this set-up doesn't provide enough signal, you can move up to the C2V or 7694 antenna to improve UHF gain down the 50 foot cable run. VHF signal loss in 50 feet of RG-6 will not be a concern.
Originally Posted by BobHaskett View Post
After mounting the antenna and adding the amp (before the splitter addition) I dropped from 23 to 21 channels.
Just took the preamp and splitter out of the equation and rescanned. Still no PBS, now I am rather confused.
BobHaskett is offline   Reply With Quote
