I recommended the HD7696P antenna because it is less directive. And as such receives better at front angles and back angles and back of the antenna.
However.
Yes you can try the HD7697P antenna.
____________________________________
I recommended the Winegard HDP-269 preamp because of the Weak signal strengths and distances to the Canada Tv stations.
However.
Yes you can try reception without the preamp.
