Old 22-Feb-2013, 3:36 PM   #7
seaverd
Thanks for the suggestion. It won't work for my setup however. I use SageTV as a DVR to record shows that I want to watch, so it would not be able to changing the antenna source. This weekend I am going to play some more with my existing hd7015 and see if I orient it toward Channel 50 if I can reliably receive that channel. My thought is that if I do, it will give me an idea of the gain needed to receive this channel. If I can lock it in reliably, maybe I will try a cheap direction antenna like the 9032 with the jointenna.
Dan
seaverd is offline   Reply With Quote
