Old 22-Feb-2013, 1:40 AM   #4
K48MN-D Real UHF Digital channel 48 , KBDI.
And K24HQ-D REAL UHF Digital channel 24 , KRMA.
Are showing these as fill in repeater transmitters.
The tvfool radar map and channel list , KBDI is showing LOS = Line Of Sight at 5.9 miles away.
And Rabbitears.info , http://www.rabbitears.info/market.ph...ility_id=22690.
And http://en.wikipedia.org/wiki/KBDI-TV.
The tvfool radar map and channel list , KRMA is showing LOS = Line Of Sight at 2.5 miles away.
And Rabbitears.info , http://www.rabbitears.info/market.ph...lity_id=167431.
The UHF band channels are 14 thru 51.
I recommend a Channel Master CM4228HD UHF antenna for reception of the 2 PBS's and other receivable UHF channels.
Aim the CM4228HD at about 130 degree magnetic compass direction.
Here is how to aim antennas , http://www.kyes.com/antenna/pointinting/pointing.html.
_____________________
Also receivable are VHF high band channels.
The VHF high band channels are , 7 thru 13.
KMGH-TV VHF high band channel 7 ABC.
KUSA-DT VHF high band channel 9 NBC.
Install a Winegard YA1713 VHF high band antenna aimed at about , 163 degree magnetic compass direction.
____________________________________________
Install the YA1713 below and the CM4228HD above on the same mast separated by about 3 feet.
The Tv reception at your location is fairly strong , and Signal Reflections from the surrounding mountains will be Fairly Strong , a signal amplifier will amplify the signal reflections along with the main signal.
I recommend try reception With Out a signal amplifier.
Because the signal reflections will make reception worse when amplified.
The CM4228HD and YA1713 are connected together with a , UVSJ = UHF/VHF Separator/Joiner. Type the letters , uvsj , in the http://www.solidsignal.com , search box.
The CM4228HD is connected to the UHF connection of the UVSJ.
The YA1713 is connected to the VHF connection of the UVSJ.
The remaining connection of the UVSJ is connected to 1 Tv with no splitter.
If 2 Tv's are connected use a HFS-2D , 2 way splitter.
Buy the HFS splitters at , http://www.solidsignal.com , http://www.hollandelectronics.com.
Some antenna aiming adjustments Will most likely be required.
Most Digital Tv's have a signal strength meter and some Digital Tv's have a signal quality meter.
________________
Here are some above the Roof antenna mounts.
http://www.ronard.com/909911.html , if using the tripod antenna mount use the 5 foot antenna mount.
http://www.ronard.com/34424560.html , if using the eave antenna mount use the #4560.
http://www.ronard.com.
By the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com , http://www.channelmasterstore.com.
____________
As always , trees and tree leaves do a good job of , reflecting , absorbing , blocking , Digital Tv reception and so do buildings and other obstructions including your own roof and house.
Install the CM4228HD and YA1713 antennas at a location that has the least amount to no amount of any type or kind of obstructions in the directions of reception including you own roof and house.
At your location the directions of reception are , south , south east , east , north east , north.
