Unfortunately, each signal meter is different. Some can go down to as low as 10 before signal breakup occurs. You will only know after observing for a few hours/maybe days. Reception on windy days is usually a good way to judge how well your system is working.
Once you connect the system to the distribution amp, that should bump up the reading on the signal meter. You may end up needing to make some fine tuning adjustments if any channels do in fact give you any problems.
