Old 21-Feb-2013, 2:07 AM   #13
Dan4328
FM traps, in-line or in the amplifier, haven't helped for any of my two other previous locations in the Atlanta metro, even with Real 8 and 10 being near each other and the FM band.
If you want to go cheap, you can use a simple Terk 1080I/1080A antenna in the room of the TV as long as it points towards the Atlanta area. Since you live a reasonable 30 miles from Atlanta, you might want to use an attic antenna simply to avoid any chance of propagation interference. Make sure the antenna doesn't point too much over 190 degrees to prevent too much signal from WATC, which might interfere on the signal from the Atlanta channels.
If you have a portable digital TV, a simple one dipole antenna or rabbit ears will do if you need to use one, but I wouldn't recommend it for use all the time because of distance.
Dan4328 is offline   Reply With Quote
