Old 21-Feb-2013, 12:44 AM   #4
Success in the attic is dependent on the type of materials used in the construction of the roof. If you have a single layer of asphalt/composition shingles on a wood framed deck and no metal/foil involved, then you're quite likely to do very well.
Consider an Antennacraft HBU-33 or HBU-44. For reception of the strong (green) signals, an amplifier should not be needed.
